brigs and straton blown?
ashman
What's a pigeonrat??
salt lake city
I just started up my power washer and after a few minutes it started puking oil out the fill tube and then died. I can't be sure but I think there was fuel in the oil. :(
It won't start now so I'm guessing I blew it. Best guess, whats up? Can I rebuild it?
Wont start as in its "locked up" ,or just spins over without firing?..
It's not uncommon for many small engines with gravity feed carbs to get the crankcase filled with gas if they were stored with gas in the tank and no fuel shut off valve,or you forget to turn off the gas..the needle & seat valve in the carb can let gas overflow if they stick open and it'll siphon into the crankcase..
I've seen a few lawn tractors do this,to the point the engine hydro-locks and bends or breaks the die cast connecting rod..
Depending how much gas was in the oil and how long it was run will be a factor as to how much damage was done...
You may get away with just changing the oil,and making sure the carb doesn't let the gas get in the crankcase again..I'd add a shut off valve if it never came with any..
I'd also make sure no mice are living in the engine's tinwork,if it was stored somewhere that mice could get at it too,their nest will make it overheat and score the piston & cylinder after a short time...
The engines can be rebuilt as long as the rod didin't break and take out part of the block or other internal parts like the bottom of the cylinder...usually its cheaper to just buy a short block or a whole engine,some online stores have certain ones for sale very cheap..
Thanks man. No issues with mice or anything like that. It ran just fine a couple of months ago and I don't have any pests around this area.
It started up and ran for a few minutes then just refused to start. I was still able to crank it over though and it doesn't "feel like" anything broke. Maybe just the spark plug got fouled badly. :dunno:
I'll try draining and replacing the oil and cleaning the plug and see how it goes.
just wanted to say thanks for the advice. I drained the oil today and I'd say it was 50% gas. :eek1:
Filled it back up and she fired right up without issue. I remembered to use the fuel shut off when I put it away this time too. :whistle:
Glad you lucked out!..many small engines get ruined from being gas washed in this manner..
Just keep an eye on the oil level,and sniff the dipstick every so often,in case the carb is flooding some while its running,to see if gas is getting into the oil..and remember to shut the gas off when its not being used..
