broke a caliper bolt.
its rusted, bolt is stock in the bracket. not the caliper. i twisted the head right off.
Heat it up and use a vise grip. It should come out pretty easily. At least mine did. I snapped both of them off on one side.
If there is any of the bolt left protruding.I would weld another nut onto it --then heat the bracket up and it should unscrew ..sometimes even if its busted off flush you can use this method sucessfully..
I'd avoid using an E-Z out,if one snaps off,they are anything BUT easy to remove!:doah:..I'd drill it out using progressively larger bits and re-tap it..
