Mudstud
OK so I broke the freakin zerk off a brand new u-joint. Stripped two easy outs and twisted off one of those square concrete studs inside it. Could push it all the way thru so hopefully I can retrieve it. Anyhow, I got the damn drill out and drilled it out real thin trying not to go into the threads. I think I was successful in NOT damaging the threads. There remains a ‘thin’ piece of the zerk still in the hole though that no matter what I do will not chip out or screw out. WTF should I try next? It's slightly under the level of the joint housing. Maybe put a srew in there with some JB weld onit and twist it off after it dries? My luck I'd weld the screw to the new joint. Guess I could fill the hole with JB weld and redrill and tap it. Any last ditch ideas? This is holding up reassembly of my axle.
Prolly should retap the hole once I get it out. You guys know what tap I would use?
