chicken joe
so this afternoon i replaced my front spring bushings. all was going well, had the right side all done and torqued. my dad was troquing the u-bolts on the drivers side, he had two done and working on the third, the eye hole for bolt position 3 broke off.
tore it all back apart and found a broken king pin, the broken anchor plate, the u bolt is sprung 3in wider, my shim hole is all tore up, and the hole in the top of the axle for the king pin is all tore up.
turns out upon inspection of the anchor plate it was cracked befor today, it was half rusted where it broke.
anyone have any ideas what might caus this??
thanks mike
thanks mike
