broken d60 shaft
muddybuddy
1 ton status
Northern, VA
im lookin for a broken d60 shaft, needs to have good ears (ujoint area). lookin to make a front driveshaft with 1480 parts. what do you have?
i have some 1480 yolks that you could modify to make work on a flange, they may be better suited to a drive shaft being that they have external rentation rather than the crappy internal which does not do as well under higher RPM's
