the bolts that hold the lock in hub on the hub. I broke one of the six little hex bolts off in to the mount I need help finding a replacement for the piece the bolt broke off in to.
You might have to get a new hub, but I'd try a little heat and a bolt extractor. Those bolts are small and can only be torqued down so much, so if you're careful you should be able to back it out.
