i have a 14bsf and am running 38's tsl radials on my burb. since i put on the 38's occasionally i get a loud snap initially when im on the gas or when there is a load (ie camping gear loaded up etc). the snapping is getting worse, and happens only when i am on the gas. it doesnt do it when the burb is coasting though, and the vibration/snap seems to come from somewhere near the rear.
is it safe to rule out the trans? the temp runs steady at 180 degrees so its not heating up at all. i have yet to drop the pan though and check for metal shavings etc...i have checked the driveshaft u joints and they dont show any abnormal wear and they arent loose.
when i open the driver door and look underneath at the rear axle, when the sound happens it shakes the rear like its gonna come right off! could this be wheel bearings, or the lock right causing my probs? where to start???
