Depending on how much room you have between your floorpan and frame rail, you could bolt on a set of F-250 shock mounts, thats what Im going to do. There is a writeup on the homepage about this, its either under Technical or Product testing, its on a frontend and uses longer shocks for a longtravel style setup, but it would work on the rear end as well.
