Wow, that’s impressive breakage !Any ideas on why this happened.
72 blazer
350 700r 205 1 tons 5.39's 40's
Cross member rubber mounts in good condition
Side brace to frame bushings not good condition
Engine mounts good condition
This stuff all exists in the stock car world, I believe Allstar Performance has them. I don’t have enough signal to load their page right now.Unfortunately, DIY4X isn’t in business anymore.
DIY4X engine mounts are the BEEF! I’ve not seen others that compare.This stuff all exists in the stock car world, I believe Allstar Performance has them. I don’t have enough signal to load their page right now.
I’ve got the flanges all scanned etc and am about to pull the trigger on making these in steel,Any ideas on why this happened.
72 blazer
unfortunately the comp mount aren't available from ORD for a 1st gen.
https://www.summitracing.com/parts/ens-3-1156g/make/chevrolet/model/blazer/year/1970 probably these, you need to keep an eye on them they will fail eventually, just not as fast as stock replacement chinesium. Be sure to match mount material trans/t case-engine all Polly or all rubber.
