The1980BEAST
What are y'alls 2Cents on the Dana 70 rear axle? I'm looking at axles now, and I know I want a Dana 60 front just wondering the difference between a 14BFF and D70 rear
the 70 is just as strong as the 14, but the 14 is cheaper to build and easier to find...
Not really true.
The 14 bolt has bigger shafts at the splines than the bigger D70's (1.625" vs. 1.5", which may not sound like a big difference but in torsion that's almost 40% more strength at the splines).
The 14 bolt shafts do neck down but they are almost inexplicably strong. They are really tough to break with any tire size that doesn't start with 5 or 6 unless you have things REALLY bound up.
The 14 bolt ring and pinion setup is better than everything else in the light duty truck applications.
Here is a relatively recent thread discussing the same, Chris Overacker is local to us and those shafts were here at one point (the candy cane ones, they must have had ridiculous amounts of stress on them, we have broken many D60 shafts, knuckles, etc but 14 bolt shafts are the the old stand by that never gets broken).
Not really true.
There pretty close in strength then. Id run either one in a mud slinger...
