KansasTwister
Its an 83 j10 4.2 i6 tf727 trans dana 20 transfer case.
He wants to sbc it, but its a driver side pumpkin. This is what i told him would be the rough idea for a swap:
Small block 350, summit sells motor mount adapters, then gonna have to worry about radiator (probably tell him to get electric fans)
He wants to swap it to a manual (he siad 465 but i also told him about the nv3500/nv4500 trans)
If he went 465, this would be easier (and shorter overall length)
Hydro bell housing and clutch (no linkage to worry about)
We would need to get manual pedals, and see if anything with a hydro clutch would bolt in as close to factory parts as possible, if not it can be fabbed (although ive never dealt with hydro clutches before)
465 trans that was orignaly paired to an np208 (i beleive these would be 30 spline in mid 80's) and then put a drivers side drop 241 manualy shifted t case on the back (is there a better tcase? im not sure on all the tcases used on the IFS rigs)
I know we would need to fab crossmembers, and do alot of work, didnt know if anyone has done a swap like this or seen someone that did and could point us somewhere for some more info.
