beater_k20
Banned
lets let it go ok?
beater_k20 said:mission accomplished.![]()
CyberSniper said:More importantly, beater_k20 is gone. I guess I can change my signature now, eh?
not yet... it was only a 3 day...
The 292 was a straight 6.beastofablaze said:Does gm really use the same block for all sbc or do they vary slightly from 292 to 400?
400 doesnt use a 3.875 crank, it uses a 3.75" stroke crank. using a 3.875" crank in a 400 block would create a 415"-427" small block.beastofablaze said:I just guessing here but probably because chevy engineered the 400 for a 3.875 crank and the 350 for a 3.480.
they have 3 freeze plugs as opposed to other small blocks 2
HarryH3 said:The 292 was a straight 6.![]()
Small block V8's share the same external dimensions, but some of the internal stuff is different, based on the engine they were building.
Yep....my "4" is a 2 plugger...4X4HIGH said:Not all 400's have the 3 freeze plugs on the side, most have the same 2 as all the other SBC's.
