Buggy pic thread
lak2004
Durango, CO
Well I am really wanting to transform my blazer so lets see some pics of buggy ish K5s. I really like miniwally's and I have seen many others too. I plan on narrowing the front and rear and boatsiding it. let the pic whoring begin!
Brandon's (miniwally) buggy doesn't have any K5 in it. IIRC it was a Suburban at one point but none of that is left.
Here's mine:
I will be adding the rear fender skins and lights along with some kind of grill on the front this winter.
OK, wally i have as my screen saver, i really like yours chris, but i havent seen it in person since we ran carnage in like march. I just need some inspiration to get my junk going and on its path
Yeah, its a little different since you saw it in March :rolleyes:
This summer turned out to be pretty intense on the build side of things for me.
Believe it or not the whole thing started out as adding a cage to my truck.
Then I figured that putting the cage into the truck would be difficult without cutting the top off :doah:
My initial plan was to build the cage and add most of the tube work that I have now, but to have a "full size" K5 that was tapered front and rear.
Then I wanted the sides boatsided. Once I cut that stuff off I decided that the windshield frame and firewall were way wider than everything else needed to be. The sawzall got a workout after that :hack:
If your goal is a buggy, start from scratch. There is so much about mine that I would have done differently (most of the tube work, for starters). Honestly, there is very little from a K5 that is worth keeping at the buggy level.
Once I had committed to building a truggy I figured that keeping the factory wiring was ok but a couple months after the truck was done I had a mystery electrical problem (nothing in the truck worked, no fuses blown, all the fusible links were good, etc.). I ended up rewiring the truck from scratch. I never found the original problem
Basically trying to fix and/or patch together the Blazer stuff ended up being more work than it was worth for the most part.
Getting the Blazer stuff to work is certainly an option. I've done plenty of it. It all depends on what you want to do.
I'm more than willing to answer your questions here, in PM's or on the phone :thumb:
definately build your chassis from scratch. I built this and wasn't happy after using the stock frame thinking it would be easier for all the drivetrain mounts.
Awesome, once I get started I will take you up on your offer.
Looks like from scratch will be the way to go then. Guess I will just keep my k5 as my driver and light wheeling until buggy is finished in about 10 years :doah:
also that blue chassis of mine is for sale I think. traded it to a friend and he lost ambition in everything
