Ok well I've had it with my dual tank setup! With the body lift the previous owner installed they make all kids of noise due to clearance issues with the body when i flex. I was goin to just raise them up again with new backets but, I would really like to get rid of them all together. I guess it has something to do with the fact that the tanks are outside the frame rails that makes me uneasy and that building sliders to protect them is PITA!
.. O and the passenger tank is the only one that works thanks to the previous owner bypassing everything when he installed an electric pump.
Im thinking of re-doing the entire fuel system with a fuel cell and new lines. Im leaning towards all ss braided and AN fittings since Ive always wanted to use the stuff and I plan to swap in a 5.3 or 6.0 at some point in the future and regular 3/8 rubber line wont handle the pressures of EFI.
Ive read all the legal stuff concerning runing a fuel cell but, since my truck is so old most emission places wouldn't know the diffrence as long as there is a fuel cap under the gas door. Ive also talked to several local and state officers who run fuel cells in their street driven cars and say its just a technicallity..
So this what Im working with a 85 gmc k20 , 9" lift , on 40's , mild sbc 350 350hp, 700r4( still havent destroyed it..), np208 , 10bolt w/ 4.10's high steer x over locked w/ hydro assit, 14sf with posi and 4.10's.
This truck is my dd (I only drive 5miles round trip to work and I have a 03 crew cab for towing duties) so I dont want to take any short cuts. My thoughts are a summit 20 gallon fuel cell with sending unit...http://http://store.summitracing.co...4294920243+400304+4294894951+115&autoview=sku
Im thinking ill mount it under the bed just behind the rear axle where the spare went and build a skidplate / crossmember for it.
Then run their fuel system kit as well.. http://http://store.summitracing.com/partdetail.asp?part=SUM-PUMPKIT7A
Which includes 20ft of 6 an line, a sumit brand fuel pump ( looks like a rebadged holley blue) summit regulator ( non return) and a summit 40micron fuel filter along with the nessecary fittings to connect it all. I just need to supply a 90* from the cell and a 8an to 6an reducer union and a fitting for the new carb.. more than likely a edelbrock preformer 600cfm.. (5/8-20 thread to -6an).
I pretty sure that -6an will flow plenty for this and or the future motor, tho if if im wrong plz tell me! My biggest concern are the fact that the regualor in that kit is return less and the fuel cell has a return..
Do I need a return to keep the fuel pump cool or can i cap it off and forget about it for now?
Also what about a second filter after the pump? Ive heard of guys running a 100micron before it and a 10micron after. Any thoughts?
What about the two fittings on top? Im guessing vents maybe install a set of rollover valves on some ss line and run them up the bedsides?
Thanx Guys,
Cory
.. O and the passenger tank is the only one that works thanks to the previous owner bypassing everything when he installed an electric pump.Im thinking of re-doing the entire fuel system with a fuel cell and new lines. Im leaning towards all ss braided and AN fittings since Ive always wanted to use the stuff and I plan to swap in a 5.3 or 6.0 at some point in the future and regular 3/8 rubber line wont handle the pressures of EFI.
Thanx Guys,
Cory
