Ned Kelly
I agree with jekbrown. Save weight at the expense of reliability? With a 10bolt you may break on the trail (maybe not - I admit some guys don't and do suprisingly well with the 10bolt, but they are the exception rather than the rule), and have to fix it on the trail, or tow it home. I'll keep things constant here, and say under the same wheeling conditions that broke the 10bolt, you would not break the D60. Worse that can happen is you may get stuck - because your D60 is ALITTLE heavier and ALITTLE less ground clearance that a 10bolt, but not overly significant. Heck, I'd rather get stuck than break something. You get stuck, winch out, or just hook up a tow strap and get pulled out - and your 4x4ing day continues. There's alot of experience on the board, and most guys will agree 36" is the reliable max for 10bolts. You won't regret a D60. What if you want to up your tire or engine in the future (it's a sickness, most of us would if we could), a D60 will handle ALOT more hp/tq and tire than a 10bolt.
I suggest you go to a parts store, and compare a 10bolt and D60 frt axle ujt. It's impressive to see how much more beef the D60 ujt has. The ujt's alone may convince you what is best for you. Compare brake pads while your there also. If you can, go compare axle shafts at your local drivetrain shop too. THis way you make an informed decision based on what you read on this board, and what you see in reality.
