Built my own steering box brace...
Twiztedmods
Oak Harbor, Wa.
Built my own steering box brace. So far it has held up. I think buying one from ORD would have been better. I guess when your on a budget sometimes you have to build stuff yourself.
Looks good. Does your frame still flex? Mine does even after using the weld in and bolt in brace, but it is significantly less. The steering also feels more responsive.
add a bolt/nut in the front position each side were the sway bar use to bolt up . it will help sandwich the area a bit more.
ya, fock that! build MORE of your own stuff! Cool thing about building your own shat is, if you dont like it or it doesnt work. You can Build it again!:waytogo:
