Also rear connector for voltage has two clips. Oil Water temp and fuel have three
Is this correct
Thanks for any help
I found some old threads that say the white bulb socket may be for a light that goes to cigarette or glove box?
Correct for both.
The white one would have a little fiberoptic cable that goes in that hole.
The volt meter only uses power and ground.
The others have power, ground, and sender
