First, I don’t want to get into an oil brand discussion. Let’s save that for another post.
my question is who buys fluids in bulk (greater than a gallon container), and if you have found benefit in doing so.
I started thinking about this after getting frustrated with the quart gear lube pumps for filling a mercruiser I/o drove on the boat. The upgrade to the pump situation was to buy 5 gal bucket and use a 5 gal pump. Worked killer, Will go through the bucket in 3-4 years. Not worried about fluid degrading in that time with my
Low humidity.
But, this search for 5 gal fluids got me thinking. Would buying 5 gal of a better oil ( maybe amsoil) be more cost effective than gallons from Walmart? Could I avoid some plastic gallon container waste, put old oil in a 5 gal, and not take 50 gallon containers to the dump every year?
This makes even more sense when you can switch 2-3 vehicles to the same oil. I already have 2 motors running 15w40 (diesel and ski boat), and May be able to switch a 3rd to the same.
The other challenge with the 5 gal pumps is how to meter what you put in. Those that do, do you have a meter on the pump like a lube shop, or do you measure in quart/gallon bottles, or what?
thanks guys!
Low humidity.
thanks guys!
