bulkhead connectors
lak2004
Durango, CO
So i am going with a mojave heater in my k5 and i need a bulkhead fitting for the firewall to run my 5/8" heater hose through. I do Not want to spend the $55 for a billet aluminum one and I want to just do push on hose barb, no AN fittings. anyone have a clue where i can get something cheap that will work? i have been searching on the web for a while now.
thanks
So basically- a rubber grommet with a 5/8 inner diameter? Could try the AutoZone Help section. Don't overlook the valve cover breather ones either.
Home depot has garden hose repair barbed fittings ( brass ) that you could use and put the hose on each side from both sides of the firewall. Did that make sense?
Tarey
Iron pipe fittings welded to a piece of strap. Drill holes for the fittings in the firewall and smaller holes in the strap to screw/bolt the strap to the firewall. Go to a hydraulic shop and buy some bulkhead connectors in whaever pipe thread you need.
Gus
http://mcmaster.com
They have want you want, in brass, nylon, stainless, steel, reducing, barbed, NPT, JIC.
Put bulkhead or bulkhead fittings in the search box.
I order stuff from McMaster all the time, great company.
But I agree with others, I think just a rubber grommet with an ID of the hose OD and pass the hose right thru, less connections is always a good thing.
damn it i wish i would have thought of less connections! :doah: i even had some expensive grommets from seal-it that i got from summit but i returned them because i was set on doing bulkheads
If you have a well stocked hardware store nearby, most of the better stocked ones have rubber grommets of various sizes there.
ill have to take a look. not too well stocked though, they never have any of the hardware i need
