Bump steer Question
AMorris1
Fremont, CA
I have a 84 K5 blazer with 33 x12.5 BFG's. I just installed a 4" Procomp lift to accomidate the larger tires, and since I installed the 4" steering arm that was supposed help my steering, bump steer went from almost non existant to very noticible. I have talked with the folks down at 4WP wholesalers several different times and have gotten a different answer everytime... take the arm off, get an alignment, etc. I think an alignment is probably my next bet, but will this really fix it, or will I have to live with it to a certain extent. Anything else I might try. I installed the lift myself, so is it possible that I didn't do something right? Any helpful comments would be appreciated!
im running a 4" superlift and 33x1250 BFG muds also and there is a bit of bumpsteer to a certain extent, nothing severe, but im sure it would be worse without the steering arm.
you need a steering box brace have a friend watch as you turn the wheels and be amaxed as you see the steering box move,I need to order on also so I know how it feels My wife wont even drive it right now
88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
Did you tighten everything up with the load on it?
<A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
<font color=blue>Happy Trails
</font color=blue>
<font color=blue>Wayne</font color=blue>
AMorris1- you're right, an alignment is your first best bet. It's not expensive, saves your tires, and you can learn alot. Find a shop you can trust, watch the alignment, and talk to the tech doing it. They will pick out any steering issues right away, and show you what's wrong. Whenever you buy a set of brand new rubber you should get an alignment. Most good tire dealers will tell you to get one.
The ORD steering brace is an excellent idea as well- (installed before the alignment)
