Bump stop extenders?
bp71k5
3/4 ton status
Knoxville, TN 37922
I've seen some of these from poly performance, but they don't look very sturdy. Anyone make some 3-4" extension brackets for bump stops? I guess I need a total length of about 8" to bolt in the stock location.
-Brian
I can't say I've ever seen "bolt on" versions for our trucks, but you can very easily make them out of a piece of box tubing with a hole drilled on top/bottom. The length of the extension is whatever size box tube you buy. Just bolt the bumpstop through the bottom hole and put a bolt through the top hole into the factory mount.
Yea, I'm just surprised diy4x, ORD, etc didn't have something already made up. Sometimes fabricating my own stuff takes longer and ends up being more expensive so I like to check those places first. :)
-Brian
Diy4x has some adjustable bumps posted somewhere. I don't know if they are a regular product yet.
