Bumper compatability
combatmatt
Crawlorado Springs or Afghanaraq
Anyone know this or tried this in the past?
Will a bumper off of a 73 3/4 ton pickup fit a 87+ blazer? are the frame rails the same width?
thanks. i found a off road-ish bumper with a winch on the inter-web for cheapo and was dreaming of being able to rescue myself when my balls get bigger than my brains.
1/2 and 3/4 ton should be the same, tons are a little narrower I think, worst case you need a little bracket work.
All fronts are the same. Rears on 1 tons are dif than 1/2 and 3/4s as said. The difference shouldnt be in the bumpers though it should be in the brackets.
NO, not directly. The frame horns are different between 73-80 and 81-87 (91 blazer and sub). On the 73-80 the bumper bolts directly to the frame horns and 81-87 the bumper bolts to brackets that bolt to the frame.
