Bumpstop questions & Spacing
rcamacho
WA
I've searched, here are some questions:
1) guidelines for bumpstop to spring distance for 4" front 48" springs and stock rear 52" springs. I'm looking to keep them from going into negative arch. ORD suggested 3".
2) guidelines for positive stop. E.g metal to metal contact. Same as #1. Guess the answer here is to ramp and test for interference in addition to limiting spring compression.
3) 4.5" extended bump stop compression limits. I've heard that they can only go 2.25" on compression before risking breakage. Some articles out there have recommended fabricating positive stops to limit compression. one idea was to provide a female box section around the OD of the bumpstop 2.25" high.
4) Square tube bump stop spacers - cheap way to space down factory bumps. Any pics? Strong enough? Too much leverage on the frame?
That's what I did. I used 3/16th square tubing. so far so good. I have stuffed the tires pretty good without bending the square tubing. the sub is not here right now but when my dad get's back from work I'll snap some pictures.
It looks kinda hack, but here you go.
rcamacho- I totally forgot to take the picture last night. I'll get it for you later. but it bacially looks like that picture but it's only one square tubing 2x2 by 3/16
Yuk!
Wow, that looks like an accident waiting to happen. I'd be concerned about additonal side load on the frame mount and separation of the two square tube spacers.
The tubes are welded together and really, how much side load are you putting on it??? how much shock load are you really putting on bumpstops unless you're jumping the truck, its been that way for several years now, and hasn't moved a bit. and i stuff the tires into the wells regularly. I would like to replace them with something better, and will get around to that someday, but its hardly something that is going to cause an accident.
RaisedK5 said:
why?? cause when a 38.5" TSL and the firewall meet, it sounds really ugly.
The sound is bad enough then you get to feel each lug grab the floor and try to play stong man with it.
smokkey1 said:
here ya go
Thanks, looks pretty good. It appears that the sway bar hold-up bracket is slightly bent though. Did it contact the axle?
no problem, I bought the disco's used from an member here. They were already like that.
I've been running the 4.5" extended bump stops for a few years now. My shocks are a tad too long (5012 on ford mounts) and the bump stops barely contact before bottoming the spring plate. Short story, I finally got around to putting some 2x3x5" rectangle tube spacers 3/16" thick under the 4.5" bump stops. I should be well into the bump before the shocks bottom now. Hopefully I can post some pictures later on and will confirm travel at the next articulation opportunity.
:doah:Well, that experiment did not go so well. Both bump stops separated internally and took off somewhere on the trail. I recall reading that the 4.5" spacers need to be compression limited to 2.25" of travel or they will fail - they sure do.
Goto advance auto they stock poly energy suspension bump stops for $12 a pair. I'll be using them front and rear.
btw the best way to measure to not neg your springs is to go from spring eye to spring eye with a piece of string, measure it from the frame with however your mounting them and as said take into consideration how much they squish, make them a 1/2in long to play it safe and be done.
