Bunch of parts a bit of everything.
jovibuilt
Registered Member
spruce pine nc 28777
I sold my 1988 suburban and have a few parts to get rid of.I can get pictures of anything you want but may take a little while.I work 12 hour days and have very little free time.
2 over head consoles one red one blue with 1 mounting bracket even have the old headliner for a pattern.$100.00 without bracket $125.00 with
1 steering column for manual trans non tilt out of a 1986 suburban $100
1 auxiliary battery tray from a factory diesel suburban puts a extra battery one the other side.$50
Hydro boost set up from same diesel suburban was not running pretty sure its all there.$100
1 diesel gauge cluster from same suburban $20
1 complete front radiator support,lights.ac condenser,grill and miscellaneous parts to do the small headlight swap like the 90-91 suburbans had.One light is broken and one of the headlight surrounds is broken.But you can get the light at advance and the surround at lmc.$200
If paying with pay pal fees are EXTRA,SHIPPING IS EXTRA!!.Only trades would be third gen camaro or Trans Am or 83-91 ranger stuff Thanks.
Also have a new 2wd steering box for a 1988 suburban bought it to do crossover steering.Was only installed for mock up.New from napa $100
700r4 and 208 tcase.Trans shifted funny but tcase is great.$125
dana 44 front 8 lug the selecto lock outs the big ones $150
A few miscellaneous parts in the pic make offer.
I can be reached here or email [email protected] thanks.
It does not fit. The roof is shaped differently (because the K5 cab ends so soon, whereas the Suburban one stays mostly flat for several feet) and the console is long enough it would stick back under the fiberglass shell (kind of weird when the top is off). To mount one in my K5 I cut a section from the front to make it shorter and then modified the headliner to remove the gap between the roof and the console. Search for pics of my overhead CB mount and you can see it.
Thanks for the insight, I'll check it out [emoji6]
Interested in the blue overhead console. sent you a pm
