Bunch of parts
patt107
north carolina/new york
Vortec 350- rebuilt 25,000 miles ago with Vortec heads with 1.6″ valves installed, CM614 1.26″ o.d valve springs, .050” shaved off the valve guides to run a bigger cam, Comp cams 8-304-8 roller cam, Edelbrock 7116 intake, GM performance Z28 oil pump, I ran this with a TBI setup on top- $650
700r4 rebuilt and upgraded with about the same miles as the 350 it was behind, can be manually shifted, has a TCI aluminum deep pan, factory stall converter for 87 K5- $450
PROCOMP part #13211 64” rear springs, brand new never installed- $300pr
PROCOMP part#13511 56” rear springs, brand new never installed, was going to run these on the front of a K5- $250pr
Diy4x 81-87 Chevy B52 kit- $150
Hedman elite headers part#69830, these fit chevy trucks without hitting the front shackles- brand new never installed- $280
33gallon K5 blazer fuel tank with sending unit and in-tank walbro 255 pump, fairly new, no rust because I undercoated it- $150
Everything is located in the Fayetteville NC area, I will ship on your dime or I can meet you within a reasonable distance, Pm me if you are interested in anything. I will take trades.
Thanks,
Pat
Man, fuel tank/sending unit/pump is a great price. Wonder how much different the gasser sending units are compared to the diesel. How many tubes does it have, and what size are they?
