Burb 4" shackle flip - what degree shims?
Ned Kelly
Winnipeg, MB
Ok, thinking of a 4" shackle flip on the Burb w/14ff. What degree shims do you guys recommend?
I searched but didn't find it.
EDIT: Who has steel shims?
EDIT: Ok, found a number of vendors for steel shims, I'm ok on this matter. JKWoffroad, WFO
The only way to get the perfect shim angle is to measure for the required angle on your truck.
Someone here might be able to tell you what shims they run, but they may not be right for your truck.
Readymix,
Yeah, I just now figured I"ll measure my current angles, and then just adjust to match them after the flip.
Thanks for the reply.
