bparti73
Registered Member
I've got two donor trucks that I want to combine to end up with one good blazer. I want to swap the 81 suburban axles (10 bolt and 12 bolt) under the 73 blazer (D44 and 12 bolt). What problems will I run into? From what I measured the burb rear spring is obviously longer, but there seems to be a bunch of threads about swapping in larger springs. Can I fit a 81 burb rear spring pack under a 73 blazer easily?
Why swap in a 10 and 12 bolt?... because they are geared lower, have a better aftermarket spring and are free!
