well, whatever, nothing else changed on that motor, and it had run perfectly up until i used 15/40wt oil, when i dropped the oil out, it was the consistancy of water and black as black could be. The cam & lifters were replaced, oil changed with regular oil it had been previously run with all it's life (after the break-in) and it never gave another problem again for the next several years up until i traded it away for a newer car.
this particular multi-weight oil was specifically designed for Diesel engines, and even though it works in gas engines, it's not a highly recommended oil for them, if it was, why wouldn't all the car makers now running full synthetic, choose to run 15/40 over their 5/30 or 10/30 syn oil? it's obviously cheaper,, supposedly performs the same as a syn oil.
Again, i realize alot of people on here are running this 15/40 oil, just my opinion that's it's not the preferred stuff to be running in a gas engine..
Hell, synthetics have been on the market for quite awhile now, and i JUST barely switched over to those in the past couple of months, skeptical, especially with the higher mileage vehicles i have it in now, but i'm keeping a close eye on it's performance and whatnot. So far, it's working out fine.
