Bushing Part # needed
Hossbaby50
3/4 ton status
Peoria, AZ
I need the part number for bushing kits for 52" rear springs. I would prefer Daystar number if possible. Thanks
Harley
from here http://www.rockymountainsusp.com/W_poly_GM.htm#Spring & Shackle
67-72
K5 Blazer, Suburban, Pickup, 1/2, 3/4, 1 Ton 2&4WD KG02006 $36
67-87 K5 Blazer, Suburban, Pickup, 1/2, 3/4, 1 Ton 2&4WD
with 1-1/2" frame shackle bushings
KG02006 $36
73-87 K5 Blazer, Suburban, Pickup, 1/2, 3/4, 1 Ton 2&4WD
with 1-3/8" frame shackle bushings
KG02008 $34
73-87
K5 Blazer, Suburban, Pickup, 3/4, 1 Ton 2&4WD
with 1-3/4" frame shackle bushings w/3950 lb. rating
KG02016 $50
73-87 K5 Blazer, Suburban, Pickup, 3/4, 1 Ton 2&4WD
with 1-3/4" frame shackle bushings w/3600-3500 lb. rating
KG02007 $40
81-87 Suburban, Pickup, 3/4, 1 Ton 4WD with 1-1/2" frame
KG02012 $47
81-87 Suburban, Pickup, 3/4, 1 Ton 4WD with 1-3/8" frame
KG02013 $47
81-87 Suburban, Pickup, 3/4, 1 Ton 2&4WD with 1-3/8" frame
shackle bushings w/2600-3500 lb. rating
KG02011 $40
