urbex
I need to go through the AC system on the '96...it's been a few years since I've done AC work, and up until a few years ago I had a buddy that did HVAC work professionally, so I had access to pro-level equipment. He's since passed away, and I find myself with the need for the vacuum pump and gauges.
I'm going back and forth on whether I should just buy one of the Horror Fright vacuum pump and gauge sets, or rent these things. I don't expect to do enough AC work to really justify even HF prices on the things, but knowing things like oil changes are more critical on vacuum pumps, I wonder if a presumably poorly maintained auto parts rental pump could potentially do damage to my AC system, or if it just means the pump won't vacuum down enough or wears out prematurely?
I don't really have a problem buying the stuff, and that's kind of the direction I'm leaning anyways, as we're talking about $120 between the pump and gauge set after the coupons....but if I don't have to buy something I'm likely only going to use a few times....
