jixxerjello
Registered Member
- Joined
- Mar 5, 2016
- Posts
- 22
- Reaction score
- 0
So i'm looking at buying a 1990 ck5, this will be my first k5 i have owned. i have went and looked at the truck twice. it has 120k original miles on it. the paint is decent could use a new paint job though. interior is good and clean. the truck starts and runs and drives great.
the only problem i found when driving it is when getting off the freeway or freeway speeds and slowing to a stop the truck will stall. everything i have researched makes it seem like its an easy and cheap fix. also the driver side electric window motor doesn't work which again doesn't seem like a hard fix and the whipper blade switch doesn't work as well the switch for cleaning the window works and the wipers move which tells me the switch has went bad. the guy wants $3500 for it, is there anything else i should check out or know about these trucks before buying it on Tuesday? any information would be greatly appreciated.
