C-10 rear disc brake conversion
SPLATT
Shelton Wa
I'm helping my brother in law build a 82 C-10 and he's getting a 05 Tahoe as an engine/trans donor. I was going through it in my head as to other parts we can use on the C-10 and I thought about the rear discs until I realized the Tahoe is 6-lug rather than 5. Does anyone know if there's a 5x5 rotor that will allow the brakes to be used on the 82?
All the after market kits have a dual pattern rotor.
Better check backing plate mount position and clocking on both axles .
I wanted to do this years ago and drum brake to factory disk was NOT a simple swap over job .
It's just that we have the entire Tahoe and would like to harvest as much as possible. If we can't use the rear disc set up in without a lot of headache to make it work we'll move on to something that will work better including just rebuilding the rear drums.
