C30 4x4 ?????
if it's a true K30, it would have a 14FF/D60, a C30 would have a 14FF, and control arms up front, since a C30 is 2wd.
So it must be a K30, because he said it was a 4x4 1 ton 1989
Close but not quite.
In '87, GM changed the "old body" style designation to "R and V" series instead of C and K. These letters ran up to '91 which was the final year for these "old bodies".
The '88 and newer body styles retained the C and K monikers.
If you check the title or VIN off that '89, you will find a "V3" in there which will tell its a 4x4 1 ton.
