C30 load adjusting brakes
79bonanza
Georgetown, Kentucky
Does anyone else have a c30 with another proportioning valve mounted on the frame over the rear axle.
I know it's for adjusting the rear brakes when the truck is loaded down.
I just never seen one on an older truck, it's an 85 C30 crew cab dually
My 91 V3500 (3+3, SRW) and TARussell's 83 K30 (3+3, DRW) both had them.
I removed mine when I swapped to 4wd but i also lifted at the same time and would have needed to lengthen the piece going to the axle, it didnt cause any ill effects when i removed it but if its not hurting anything for now I say leave it.
Both of the trucks I mentioned were bypassed, no ill effects.
