Since most of my questions are F.I. related I posted here vs the engine swap thread. Mods, please move if you think it's in the wrong spot.
I’m going to do a C.A.R.B. legal “engine exchange” and replace my 1985 5.7 w/CCC with a newer F.I. motor/trans. Unfortunately, I will have to swap out my current 700R4 because it is equipped with a 1985 only sensor that retards the timing when in O.D. The sensor started leaking and I just installed a bolt and ziptied the wires up out of the way. Smogging hasn’t been a problem since the techs aren’t looking for a computer connection to the trans. However, the referee will be closely examining my Blazer and the bolt is a no-go.
Requirements:
I’m looking for a reliable daily driver/road trip vehicle. I don’t need tire burning horsepower. I do want to be able to drive up to Tahoe, go over the Grapevine etc and not be stuck in the truck lane behind a motorhome.
Will TBI meet my needs or is it such old technology that I won’t be able to find parts in the next few years?
If TBI is still viable what years should I be looking for and can I use my current transfer case? (darn budget)
Would TPI be a better solution? If so, what years? At what point will I have to ditch my current transfer case? I don’t want to go so new that I will have to retrofit a bunch of sensors (fuel cap etc).
Thank you in advance for your suggestions
Requirements:
so I have no first-hand experience with it.
