Really think I need to rewire? They all work but my buddy broke the one lenson the truck now = NOT original .
in the bag is the lens only for what you DO need . note the holes in the roof for the correct style.
you also need the rubber and wire plug kit to make it work .
best bet if me buy a new master kit and be done with it . and use the wire feeding them now as the fish for the new kit install.
I mat do that for the time being but now that @sweetk30 pointed out the holes I have to at least seal them up to keep the h20 outif you just want to replace the one lens go to a truck supply store they will probably have the one you need.
If you mean the screw hole, I'm hoping they're all within the seal area. Changing the sockets should prove to be too difficultand looking at the new style on it you might be in for some work .
