SafetyHelmet
Registered Member
Hey guys,
I'm about to grind a ton of rusty metal out from under my cab body. Before I remove it, I'm curious- is the cab really just one layer of sheet metal? For example, my rocker panels look great on the exterior.. from underneath it looks like there is a whole extra layer of rusted out metal that they laid new metal on top of. It all appears to follow the same contours and lines as the good stuff.. Can I just grind this out, prime it up, and be done? Or should I weld in some reinforcement somehow?
Been trying to find a good exploded diagram of the cab sheet metal, but no luck so far..
I'll take some pics this afternoon if that would help explain. Half of my K5's floors are diamond plate, the P.O. went over the top of the original floor, I think. If it helps answer the question, I will be using 16ga sheet steel stitched in with MIG welding.
Diesel, like I said........
Perfect solution to crappy headliners. The 'Zip System' that's replacing Tyvec...great liner,awesome rubber tape...
..I wanted that size for my wood stove when I saw it,but the guy said the zinc would make me ill if used indoors,and it was about 10 bucks per foot...pass!...
