Wanted Cab mount braces
thatK30guy
1 ton status
Looking for a pair of these braces which are right under the very rearmost cab mounts and cover the fuel tank selector valve. Not all trucks had them. I need a good set off a K30 due to the 8" tall frame rail height.
Let me know your price and some pics.
$100 plus shipping for my time. The plan would be to cut the frame and crossmember around the brackets you need. You can knock out the rivets on your end.
never seen them .....
and nice clean frame to scrap . us rust belt guys would drool over that one .
Those are cool, I’ve never noticed them before.
@kennyw I'll take the passenger side but not driver since it's not the correct piece to match.
@kennyw put me in line in case you come across a second set.
Any difference between 2 door and 4 door?
If you're only selling them as a pair then I'm out as one bracket isn't correct for my use. I'd buy the passenger side but I understand if you don't want to separate. Let John have them if he wants.
If he doesn't want the pair, then I would be willing to sell the single. I just know the left over single will end up in the recycle bin once separated.
@thatK30guy what exactly was not right for you with Kenny's brackets? Is there is a different version or something else? After receiving these they are both frame thickness, etc, so I'm curious what else is out there. (I got these for @tarussell, I wish I could find something like this for my Blazer.)
John, take a look at the driver side on my pics. They look almost identical to the passenger side as far as shape and form goes.
I see now how the driver's side is formed so it's closer to the vertical wall of the frame. Do you know the reason / advantage for the difference?
Still looking for a pair of these. There's gotta be some out there somewhere.....
