Cab mounts
TJ1978
I have MANY questions
East Valley, Arizona
I recently purchased a set of new cab mounts for a 69’ c10 from classic industries. They arrived but with no instructions. I know how they are installed but the question is, where does the fatter of the two go, front or rear? The sizes are different I emailed classic and have had no luck in a response.
i watched brother videos on the install but how they distinguish between them are different from what I have from classic. Brothers have a meta type plate on the rubber and the other is just rubber. The cab mounts from classic are all rubber or at least there is no sound difference from tapping them
since the cab mounts on the truck bare little if any resemblance to the new ones I can’t use that as a way to tell the difference.
I found a few posts elsewhere that say the larger goes in the rear mount position.
why don’t these companies provide instructions, either paper or pdf on the site? Lokar is able to provide this info...
If you go to energy suspension you should be able to find a pdf.
Ha I'm not sure about this company. My body kit came missing 6 pieces I left a message last week, no reply, nothing so far.
So I am unable to recommend them for anything atm.
