Fiddlin with installing CB radio and checkin fuses to see why no brake lights and bumped the non-fused side of a circut to the turn signal flasher deal. Now there is no power at all in the cab at any fuse either side. I have eliminated all the excess wiring under the hood and ran a large 10ga wire to a jnct block at the firewall then tapped back into the factory wiring that goes into the bulkhead connector into the fuse box. I have power at the jnct block but nothing part that when it goes into the cab. I haven't pulled the fuse box off the firewall yet, hoping there might be a commen problem or another fuse link or something where it come into the cab that I don't know about.
