Cab roof question 1991 GMC - Drilling
RJB44
Northern Virginia
I am interested in installing a combination map light and clock unit in the cab of my 1991 GMC Jimmy. I want to put it front center on the inside header area. I have the one piece molded unit with wiring. I want to assume that the sheet metal for the cab roof is two ply, meaning if I drill screw holes from the inside, I won't end up going through a single layer to the outside the of the roof. there are two screws that support this unit. I have puilled back my header material but just want to make sure I am safe to drill in that area. Thanks
RJB44
RJB44
My 76 cab had 2 layers so i am pretty sure the 91 will too.
:D
Yep. 2.5 to 3" front & back and about 3/4" in the middle.
Over the windshield there is some bracing as well.
RJB44
I'm not sure but the LMC catalog may have the parts breakdown.:D
