cab
Im about 90% sure that it will be a direct bolt on. I think 78 or 79 is the year they changed the blazer frames. Just look to see if the cab mounts on your k-5 frame, behind the front seats, are inboard of the frame. If they are, then you are good to go!
The cab mounts are on the inside of the frame behind the seats. So I guess I'm good then. Thanks
