Anybody seen one or know where to get one. I'm gathering ideas for my custom console, and I'd like the t-case shifter to be mounted in it. It'll be tall enough so that the floor shifter would be useless.
It shouldn't be too hard to adapt something , the lever on the case is NOT gated or anything , it just rotates .
The original shifter has a stop so you have to go to the side and down for 4 low .
So maybe some kind of auto car shifter backwards with cable out the front , with you making the bracketry , and using the stop and lift it for reverse to go to 4low . You could weld up the extra gear stops so 2nd and 1st are 2hi and 4hi , lift over neutral for 4 low , and park is gone .
Just thoughts . Don't know if I am even on the right track .
It will click in the case , shifter will move free with rod disconnected .
You still have to have something that prevents 4low from just happening at any speed . Thats why the factory has the little stop you have to go past .
I should of said shifter is free except for that .
I was think a person could make their own plate to operate the shifter and keep it from accidentally going into 4lo.You still have to have something that prevents 4low from just happening at any speed . Thats why the factory has the little stop you have to go past .
When I was in High School I had an '86 Cutlass Salon(trim upgrade to the supreme) it had a console shift, ran by a cable. IIRC the cable was about 12" long, maybe more. So build your custom console use your shifter and stop plate, attach the cable, fab some brackets. Good To Go!Anyone else have some ideas?
