Sooo....I finally got my strong box from bohemoth drivetrain (only took 3 times longer then told
). I want to use a triple stick cable shifter setup, most likely the buggy model from JB fab.
My question is about cable length, this is going into my standard cab behind a 454/400 and my plan is to mount the shifter setup a little higher and more towards the driver. This is the shifter I'm thinking of http://jb-custom-fabrication.myshop...le-dd-box-4-rocks-buggy-style-p-n-trcsddbfrby Just trying to determine what length cables I need, anyone running a somewhat similar setup?
). I want to use a triple stick cable shifter setup, most likely the buggy model from JB fab. My question is about cable length, this is going into my standard cab behind a 454/400 and my plan is to mount the shifter setup a little higher and more towards the driver. This is the shifter I'm thinking of http://jb-custom-fabrication.myshop...le-dd-box-4-rocks-buggy-style-p-n-trcsddbfrby Just trying to determine what length cables I need, anyone running a somewhat similar setup?
