A TBI Caddy would be sweet![]()
Coming to a screen near you!
I just picked up a 68 caddy with 37,000 miles on it for $150. a little research told me that the 472 in this year makes 375 hp and 550 ft-lbs of torque at 3000rpm. the 70 models made more than that. put an aluminum intake on em and they only weigh 40lbs more than a small block chevy, get a hei dizzy out of a 74 or newer model to do away with the points ignition. I can easily find these motors dirt cheap, it seems like nobody wants em. that being said, I just sold two high mileage 454s, (smogged out truck motors that only made 160hp) for $800 each. it would have taken a lot more money to get em to the 375hp 550ft-lb range. that is the benefit of a caddy engine.
Second thing, I'd like to see where you found any 454 rated under 200 hp SAE net. 160 hp SAE net is what the smogger carb'd 350's were rated at.
Rene
You're comparing apples and oranges my friend. First off anything before '72 was rated in gross hp, everything after '72 was rated SAE net hp. An example I can think of off the top of my head to get an idea of the difference is this: '71 Dodge 318 was rated 230 hp gross. Identical engine in '72 was rated 150 hp SAE net. The gross ratings you could take with a grain of salt too...many engines under rated, many over rated. The numbers were whatever the big 3 published them to be, and often the reality was different. The SAE thing standardized things...
I've never been a big fan of Caddy engines, I'd take a Buick, Olds or Pontiac 455 over the Caddy 425/472/500 any day of the week.
Of course the cubic dollar solution is the motown 454 sbc from World products. Pump gas, 600 hp, EFI, probably 100 lbs lighter than the caddy, and it would bolt right in...of course it is a small $20K
Rene
and guys the headers are not that hard to come by for our trucks, just get a set of 454 headers, then call dec headers and order a set of caddy flanges, cut em off the 454 headers and weld the new ones on.
Have you ever done this?
myself I just got two driver side manifolds flip em over and ran em through the hood.I have never done it myself, but read about it on some caddy site, they also said that depending on what you are putting the engine in you could also use 460 ford headers with caddy flanges. I seen it on the internet so it must be true.myself I just got two driver side manifolds flip em over and ran em through the hood.
), second one is close. Third tube is far enough off that you need to start cutting stuff apart to make the adjustment and the fourth one is not even in the neighborhood. So, its not all bad, you may have to fix two tubes per side and adjust one with some heat and persuasion. Depending on how the headers are layed out will determine how bad it actually is to do. Since I've only done it once, maybe there's a better header out there than what I used.Might be easier to work "center out"? Less accumulative error I'd think...
Rene
I would go with a rosebud, BFH and a pipe stretcher, but that's just me.Might be easier to work "center out"? Less accumulative error I'd think...
Rene
Do you guys remember when Hot Rod magazine took a stock Chevette and threw a 500ci Caddy in it? It was like 10 years ago, and i was just a kid when it came out and remember thinking it was one of the coolest things ever.
The engine stuck halfway into the cab or it would smoke the tires all day from being too nose heavy. lol
