Cadillac V8-6-4
Craig Artzner
3/4 ton status
Northeast Ohio
I was reading about this one-year-only engine from Cadillac that was available in 1981. Just found it interesting.
From Wikipedia:
For 1981 Cadillac introduced what became the most notorious engine in the company's history, the V8-6-4 (L62). The 368 had not provided a significant improvement in the company's CAFE numbers, so Cadillac and Eaton Corporation devised a cylinder deactivation system that would shut off fuel to two or four cylinders in light-load conditions like highway cruising, then reactivate them when the throttle was opened. A dashboard "MPG Sentinel" gauge could show the number of cylinders in operation, or instantaneous fuel consumption (in miles per gallon). The L62 produced 140 hp (104 kW) @ 3800 rpm and 265 ft·lbf (359 N·m) @ 1400 rpm. Cadillac hailed the L62 as a technological masterpiece, and made it standard equipment across the whole Cadillac line.
While cylinder deactivation would make a comeback some 20 years later (with modernized technology), Cadillac's V8-6-4 proved to have insurmountable teething problems, both mechanically and electronically. The biggest issue was that the engine control computer was simply not fast enough or powerful enough to efficiently manage the number of cylinders in operation, so many of these engines had their variable-cylinder function disabled by dealers, leaving them with permanent eight-cylinder operation. The 368 was dropped for most Cadillac passenger cars after the 1981 model year, although the V8-6-4 remained the standard engine for Fleetwood Limousines and the carb 368 remained in the Commercial Chassis through 1984.
Pretty simple it was a POS that wasn't worth the trouble it took to unhook it. Maybe modern technology got this idea right finially
George
I never heard anything good about those. We'll see how the new cars do, give it a couple years, and we'll see...
From Wikipedia:
I've driven one...lots of pinging going on there!!!:doah:
I dunno about that statement, I thought the 4.1 was the worst thing they ever put out. At least the L62 cylinder deactivation portion could be bypassed, the 4.1 just flat out sucked in every regard.
How exactly did Cadillac deactivate the cylinders? Was it a port injected engine and they just shut off the injectors, or was it something like intake valve solenoids?
My boss purchased one of these 8-6-4 Cadillac in 1981. On his way home, the day he purchased this car, from Lexington to Ashland Ky ( about 120 miles ) he was going 80 MPH on the interstate when it went from 8 to 4 cylinders. The engine died, he could not get it to crank in neutral ( probable needed adjustment ) it had quick steer power steering - the steering effort was tremendous with a dead engine, and no (power) brakes. He had two feet on the brake with minimal results. The man was 63 years old, he said that his life flashed through his mind, and believed he was going to die any minnuet . Luckilly there was no other cars or big trucks near and he finally got it to stop. Once in park the engine started. He looked through the owners manual and found the fuse that turned off the solenoids. He got rid of the Caddy the next day!
They had hugely tall valve covers that had solenoids to deactivate the center cylinders as called for.
