Calibrate Fuel gauge
aknight_sa
Saudi Arabia
Good day guys
I see this problem a lot where the gauge isn't calibrated correctly. When it's full it passes the F significantly.. Is there a way to fix this.. I need to have the full at the F
Here are some previous discussions on this topic. Keep in mind there is an inherent non-linearity of the sweep since the float is swinging on a pivot instead of actually sliding straight up and down. The sender may be "maxed" for a certain range of positions, in which case there is no way for the cluster to distinguish the difference. Only options would be to a different sender or bend/reposition the float on the arm, which could cause the same problem at empty.
https://ck5.com/forums/threads/can-a-gas-gauge-be-calibrated.282195/#post-2875259
https://ck5.com/forums/threads/gauge-issue-stock.262226/#post-2618140
https://ck5.com/forums/threads/tuning-stock-gauges.256107/#post-2542559
