I've had Autometer gauges in my truck for about 5 years now and they are starting to bug me.
First problem is, my fuel gauge does not read correctly. When I initially installed it, it was close to correct, but over the years it tells me that I have more gas then I actually have. For example, when it tells me I have 3/4 of a tank I actually have about 1/4 tank. Is there a way to fix this?
Another problem I am having is my oil pressure gauge reads backwards, and I hope it's not correct if it's backwards. At idle when cold it reads 75 psi, then when it warms up and is idling it reads off the gauge like it gotten more pressure. I have the gauge wired up through the ECM for my TPI, but I also have the sending unit that came with the gauge. Is there a spot I can hook up the autometer sending unit other than the back of the engine where it is in the stock location? it's kind of a pain to get back there, and I'm not sure I'll have the clearance with the firewall...
