caliper bolt size and thread pitch
YELL78
ALBUQUERQUE
hey guys im in a pinch i jus got my DIY caliper brackets for my 14b and the threds in the mounting holes are all flat and i ruined two new caliper bolts before i realized what was going on. can you guys tell me what size and thread pitch the caliper bolts are so i can tap them and get my truck going again thanks alot for any help
If the threads are all flat then they cannot be re-threaded to the same size, you'd have to tap them to the next bigger size.
the threads are still there they just need to be chased with a tap i just need to know what size and pitch
are you talking the bolt that holds the caliper to the bracket or the bolt that holds the bracket to the axle tube flange?
