caliper clearance
79rustyk10
3/4 ton status
Bikini Atol
I searched and couldnt find much, but will a 15x10 with 4" BS fit with my 3/4 ton D44? Or should I look for a 16" wheel?
Im planning for 35's as the largest tire Ill run in the forseeable future, and I plan on rear disc's as well.
Grinding should be minor, get a can of spray paint and paint the caliper and while the paint still wet put the rim on and spin a few times.
The spots that need grinding will rub the paint off, keep repeating process until rim clears and no paint rubs away
It will fit. Ive done it.
Youre gonna have to grind quite a bit, off the bracket and caliper.
I run 15x10 4.25" BS steel rims and I had to grind a decent amount. It's really not that big of a deal, just plan on grinding.
With 3 3/8 backspacing and a 15x10 i had to do some grinding but nothing extensive...thats with the d60 and d44
